cory4788 Posted January 20, 2013 Report Posted January 20, 2013 Hi, I have a AQ2200 on 2 SA-12s and I wanting to add an extra battery. But I have no clue what I am looking for in a battery and which one to get. All the electrical is stock and its going in a extended cab Sonoma if that helps all all. I do have 0 gauge wire running from front battery to amp. Any help would be greatly appreciated. Thanks
08tahoe Posted January 20, 2013 Report Posted January 20, 2013 Check out xs power batteries. Also do your big 3. For what you have you should upgrade your main battery to the biggest xs power D series batt you can fit under the hood and get an extra one. I would go with a d3100 for the extra one. You should be good after that, but get a volt meter so you can keep an eye on your voltage, if it drops to low then upgrade your alt.
cory4788 Posted January 20, 2013 Author Report Posted January 20, 2013 Yea, I'm going to order some wires to instal the battery and do the big 3. I already have a stinger volt meter. So you would recommend a battery up front and in the back? Would just a good battery in the back be good along with the big 3?
08tahoe Posted January 20, 2013 Report Posted January 20, 2013 yes i would recommend upgrading your front battery also just because thats what i did but some people run the stock battery in the front and just get a second batt and say they have no problems.. Here read this: http://www.stevemeadedesigns.com/board/topic/126237-mixing-a-regular-wet-cell-and-an-agm-battery/
cory4788 Posted January 20, 2013 Author Report Posted January 20, 2013 Yea I've heard people running with the stock and not having problems but other people say you shouldn't do it. I think I'm going to try and just put a battery in the back at first. Hopefully that will keep the voltage up. I gotta see how big of a battery I can put though cause its going in a extended cab Sonoma so space is a issue Lol.
Watch the bass Posted January 20, 2013 Report Posted January 20, 2013 Get 2 of those http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/ "in the abundance of water, the fool is thirsty" Bob Marley
cory4788 Posted January 20, 2013 Author Report Posted January 20, 2013 Get 2 of those http://www.stevemead...ike-a-bad-deal/ I was actually looking at them. You think one in the check would be good? Or 2?
cory4788 Posted January 22, 2013 Author Report Posted January 22, 2013 What about C&D batteries? Are they any good?
