help with gain settings
Big-A
need a little help as my amp will go into protect on bass heavy songs played for a long time.
input voltage 14.1dc 60hz test tone.
Alpine head unit 75% volume, loudness off and "0" on all settings.
clarion eq with master volume and sub volume at max. all other settings at 0.
output voltage is 45.2ac with subs unhooked. the sub Im running is Obsidian Audio 12d2 wired at 1 ohm.
Turned gain back down till I was around 25 v ac. Just surprized to get 45 with no audible distortion.
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
Arc Audio 600.1
2004 Dodge Ram
Big 3+ with SHCA
amp is rated at 600 into 1 ohm and the tech guys at ARC told me they were seeing at least 700 rms. If im reading the chart right should my output voltage be around 26-27 for 700 rms?
2004 Dodge Ram
Big 3+ with SHCA
does this happen when idling?
where is your ground? is the paint sanded off?
are you using 4 gauge?
46v into 1 ohm is 2000 watts. you're clipping the ever living FUCKING SHIT out of that amplifier. like 2/3rds of the amps output is straight up distortion.
Thats what I thought but I swear there is no audible distortion what so ever? The sub is in the truck in a console box and i have had my ear right next to the sub with no distortion heard? Makes no sense to me
2004 Dodge Ram
Big 3+ with SHCA
But Im gonna back that voltage down a little.
2004 Dodge Ram
Big 3+ with SHCA
0 guage, small xs battery and ground is a through bolt on the frame. Amp never gets hot either.
2004 Dodge Ram
Big 3+ with SHCA
Find someone in your area with a dd-1, that is the best way to set amp gains
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   1 Member, 0 Anonymous, 1185 Guests (See full list)
