oakteg21 Posted January 24, 2013 Report Posted January 24, 2013 I have a 2000 acura integra hatchback looking to make a enclosure for my 2 ssa dcons i bought. I have a hifonics brz1700.1d amp i will be using i know its alot of power for them but i will be careful with the gains. Anyways i dont know really how to make a enclosure design and need help. Im looking for the design to be subs up port back tuned to 32hz and max dimensions i could use is hxwxd 13x28x22 in.
Joe X Posted January 24, 2013 Report Posted January 24, 2013 So here is a suggestion: Enclosure Specifications: Fb = 32.3 Hz Vb = 2.45 ft^3 External Height = 13.75 in External Width = 28 in External Depth = 19.25 in Port Width = 2 5/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Top & Bottom = 28 x 19 1/4 Left & Right Sides = 17 3/4 x 12 1/4 2x Front = 12 11/16 x 12 1/4 Back = 28 x 12 1/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 16 7/16 x 12 1/4 2 x Extension = 8 15/16 x 12 1/4 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - The port needs 2 5/8" of free airspace in front of it for proper operation. - Setting your amp's subsonic filter to 25-28Hz is suggested.
oakteg21 Posted January 24, 2013 Author Report Posted January 24, 2013 Thank you awesome design yes i would use the 45s.
Sonic Posted January 24, 2013 Report Posted January 24, 2013 Thank you awesome design yes i would use the 45s. Haha, now send the guy a $10 paypal
DubNBass Posted January 24, 2013 Report Posted January 24, 2013 cant go wrong with Joe x designs. he did a blue print for my friends dual p3 it hit harder then a pre-fab he had. .
Joe X Posted January 25, 2013 Report Posted January 25, 2013 Thank you awesome design yes i would use the 45s. The 45s inside the port have to be done in a way that at the port turn each side has 1/2 of the port width as shown here: Also in your case the 45s in the back corners should not be done.
oakteg21 Posted January 25, 2013 Author Report Posted January 25, 2013 Thank you awesome design yes i would use the 45s. The 45s inside the port have to be done in a way that at the port turn each side has 1/2 of the port width as shown here: Also in your case the 45s in the back corners should not be done. Ok understood wow thanks i appreciate the help i will hopefully get this done on tuesday thanks for your help
oakteg21 Posted May 21, 2015 Author Report Posted May 21, 2015 Been a while since being active on the forum but giving a update after 2 years or so got to say still have this box and set up on my car and very happy and pleased with it and yet to think about changing it since its that good for what i have! sure recommend anyone that have a similar setup to use this box design.
