Box for components?
Mobileaudio25
Most of them don't need a real enclosure. Sealing your doors usually works well enough. Just add as much weight to the baffle as possible to prevent rattles/resonance. If you use home audio speakers they may require some monkey coffins but I can't see any that many people would use requiring more than a cu. Ft. max What comp set are we talking about?
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
They free air in alot of cars such as mine.
So just putting them into the rear deck would be fine? Ditch the small boxes?
You could but if the subs are back there to it will roach your speakers. In that case the small enclosures will protect them. :)
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
Yes. I've heard a lot of complaints about small enclosures killing bass response. Not that you should expect massive bass from mids n highs, but just sayin...
Free air is fine.
Ooo good point didn't think of that
Either are fine. I had to use enclosures because free airing them in my door kept frying them due to the seal on my doors is messed up and water kept leaking in. And since that now I only run 1 set of components and 2 super tweeters, built 2 enclosures for them and put them behind my seat, but up at your head, in between the box and the panel. Worked out pretty well.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   0 Members, 0 Anonymous, 1136 Guests (See full list)
