Ok so i need some help from someone knowledgable. To keep a long story short the pcm on the vehicle (1999 yukon) is looking for a signal from the crank position sensor, and the motor i have doesnt have one. (motor is a 5.7l 350 from a 1990 firebird) the motor does have a timing slot in the harmonic balancer. What i was wondering was if i could make a device that would be able to read the timing mark and send the signal as the crank sensor. The timing mark i am refering to is a physical groove in the harmonic balancer. Any ideas?
This page is crispy_chick3n approved.
© crispy_chick3n inc
contact a tuner and see if they can just turn off that sensor in the PCM
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
What i have seen people do, is weld the reluctor ring to the front of the harmonic dampner. then they rig the crank sencsor to the lower right side of the block to read the reliuctor out front. Are you running a distributor? If so then no biggie, but if not, you need that timming reference.
<>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
