Omega5002 Posted January 27, 2013 Report Posted January 27, 2013 Well, I never said go by the peak, just stating what's said. You don't have to turn down the gain all the way if you get it properly set with an Oscope or preferably a DD-1 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Guest Posted January 27, 2013 Report Posted January 27, 2013 it's impossible for the sub to have a single coil when you said it can be wired to two different ohm loads
Omega5002 Posted January 27, 2013 Report Posted January 27, 2013 and plus the GT-5 only comes in 4 ohms svc, now unless you're running 2, then the 8 or 2 ohms thing isn't making sense. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Jessica Posted January 27, 2013 Report Posted January 27, 2013 I think it has become obvious you don't know what you are buying. If the specs say 2-8 ohms then it is a DVC with two 4ohm coils. It can be wired either 2ohm or 8ohm. I'm guessing you havent bought the sub yet. Is this something you are going to buy of the web? If it is post the link to it here. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
medwards420 Posted January 27, 2013 Author Report Posted January 27, 2013 already bought...ill just have the stereo shop figure it out for me ...thanks....btw I know what I bought
Guest Posted January 27, 2013 Report Posted January 27, 2013 already bought...ill just have the stereo shop figure it out for me ...thanks....btw I know what I bought i dont think you do. you are contradicting yourself. you say that its a single voice coil, but you say that it can be wired to 2 or 8 ohms. it is impossible in the land of physics for both of those to be true. take a picture of the woofer and post it on here....
CleanSierra Posted January 27, 2013 Report Posted January 27, 2013 A single voice coil sub can only be wired to a single ohm load. please read up before you continue to post meaningless junk. What does the box say or like Kranny said, post pics of the sub you purchased. Im not the one you want to try to troll. Just a fyi for you.
medwards420 Posted January 27, 2013 Author Report Posted January 27, 2013 sorry guys, its the gt5-10d my apoligies.....not the svc, will i still be ok on this amp? Thanks guys
Omega5002 Posted January 27, 2013 Report Posted January 27, 2013 Aha knew it It should be fine, just make sure to set the gains correctly. Try to see if you can locate someone in your area with an oscope or dd-1. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
