Integra bad gas mileage
okay so i did my calculations wrong and im getting around 19 mpg....so would driving habbits change my mpg that much?
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
if you're heavy on the throttle all the time, I don't see why not. but I get 18 for a 3.8 v6. car weighs about two tons.
you should be getting like mid twenties or thirty if you coast a lot, I dunno.
You should easily be getting 30+ even if you're heavy on the throttle.
I disagree. 30+ while heavy on the throttle is not likely when most Toyota and Honda vehicles barely achieve a little over 30 mpg when tested for marketing. When they test for vehicle fuel efficiency they don't do much heavy throttling. Driving habits do effect your bottom line I don't care what anyone says. So many variables factor in but even under the most perfect conditions driving habits can and will rob fuel mileage.
4 American Bass VFL 8" at 0.5 ohm
Soundstream Tarantula 3000.1D at 0.5 ohm
32 hz ported box designed by Mark at Car Audio Fabrications
XS D1200 secondary with Stinger isolator
I disagree.
That's fine, but you're wrong. I've owned a 94 integra, and I would average 32-34 city driving. The lowest I ever got was 28, and that was beating the hell out of it.
2 HDC3 18's
AQ2200D
I feel your pain. My fucking camry gets 17 city. Pointless 4 cyl.
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
I disagree.
You must be the luckiest person who ever owned an Integra. :)
