Integra bad gas mileage
So I've only been getting 250ish km per tank and people say I should get 450+ I'm only getting 11.5 mpg :( any help
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Empty sub box in the back but this was all before that, just changed oil and spark plugs tires are new and holding air!
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
Engine seems fine although when I rev and rpms drop they stop for a second a couple hundred about normal then continue to drop back down to that number, I did seafoam via gas tank and spray in intake so we will see how that works
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
So many aspects of a vehicle can effect fuel mileage. A few preliminary checks are in order as well as further info such as year of your model and what engine if there are any varying sizes for your year/make/model.
Do you have a check engine light on?
Is your air filter clean?
Is your tire pressure evenly matched at no less than 32 no more than 36 psi?
Do you have any exhaust leaks?
Have you had a tune up (plugs, wires/coil boots, distributor cap and rotor button, pcv valve if that vehicle is equipped with them)?
Have you changed your fuel filter?
Have you changed where you fuel up at?
Have you tried any types of fuel treatment from a parts store?
Have you changed your oil?
What weight oil do you use in your engine? Synthetic or not?
Have you ever had a compression test done? A compression leak off test?
Under your hood do you see any noticeable sensor harness' unplugged or broken?
Do you see any vacuum lines broken, or hear any hissing while the engine is idling?
Do you see any igniton/spark plug wires touching exhaust or anything hot that could compromise their insulation? Possibly rubbing something from engine vibration?
Have you checked your brakes to verify you don't have a caliper or caliper slide pin sticking and/or over adjusted rear brake shoe/e-brake?
Does your engine coolant temperature gauge read low? Not read at all?
Answer those and/or verify and I will be more than happy to lend a hand to get you back in the realm of mileage you should expect from an Integra.
4 American Bass VFL 8" at 0.5 ohm
Soundstream Tarantula 3000.1D at 0.5 ohm
32 hz ported box designed by Mark at Car Audio Fabrications
XS D1200 secondary with Stinger isolator
