IS IT OVERKILL
Im installing 2 15" alpine type r subs with a Alpine MRX-240 (2400 watts @ 2 ohms, 1500 watts @ 4 ohms) mono amp at 4 ohms. Im am upgrading my stock battery to an xs D3400 battery, a high output alternator (mechman 240 amps), the big three upgrade with 1/0 gauge wire, and amp wired with 1/0 gauage wiring kit. Is this overkill for only 1400 watt amp?
Nothing's overkill until you blow something up :P lol don't listen to me, I have no idea
My Build Log
Heros get remembered, but legends never die.
No such thing as overkill when it comes to electrical sir ;) Although you should be alright with just the D3400 and big three upgrade. If you see yourself upgrading soon to a more power hungry setup then you could get the alternator now if you really wanted to.
Edit: just saw you corrected it as 2400 watt. Yeah I would say go with the Alt as well. Make sure the wire you are using is OFC, or do two runs of CCA.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Only the alternator.
The big 3, 1/0 and batt are all a good idea, esp if your running at 2ohms
Yeah im looking to install another amp for all 4 door speakers and component speakers and tweeters later
wattage?
specifically amp specs...
  • Who's Online   0 Members, 0 Anonymous, 1022 Guests (See full list)
