So putting a D5100 in my car was a bit painful but I did it.. some modding took place because it was not a d5100R but owhell cant complain because of the deal I got for it.. NOW PIC'S
Before
The Battery
Me just realizing I have my work cut out for me on this one.
My solution was to buy a copper bar and use that to extend where the terminals where but I could not find copper so I used aluminum
My voltage dropped to 12.5 before with the stock battery (also pcm controlled alt) so with this one it should do much better...I hope lol
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
So it is day 2 of the battery being in and car has not blown up yet... I think its good.
141 on music.
Well I removed the batt from under my hood. I was getting wearied flickering lights when I was at idol from the way I had to wire it so I put the oem back. Now I'm coming up with a plan to still use it but just keep it in my trunk and use my 4awg run and connect it to that then to grounds and THEN just have my amp connected to that battery.
141 on music.
  • 3 months later...
Update and pics tomorrow. but for now i have changed my headlights. i did not put HID's in but i did get some top of the line sylvana's for my lights. I have not done the high beams just yet (bulbs cost alot lol) but i did to my regular lights and my backup light and let me tell you how much of a diffarance it made.
141 on music.
Ok i slacked on the headlight pics lol but a little update. so i got a little monies for xmas and i just ordered some of Soundqubed's Q-mat... there car kit. i probly will use it in the trunk so i can tame some of the noise thats not suposto come from the back ^_^.
141 on music.
instead of putting the battery in the trunk you could replace the battery wiring with better wiring, 1/0 gauge for instance. and for a run front to back you cant go wrong with 1/0 gauge wire. less resistance and more power to the amp.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
That is my next plan after i deaden the trunk and get some $$$$ saved up. Plan in doung 1 run of 1/0 shca ifc to the rear plus 2 grounds of 1/0 and the. Run 1/0 do the amp with 1/0 to 4gague reducers
141 on music.
ITS HERE!!!!!!...GET OFF MY BOX CAT!!!
Came from DD lol
141 on music.
