RCA question !
MY head unit only has 2 outputs front+rear and i have a 4 channel and monoblock which i need 3. currently i have front and rear running to 4 channel amp. then the output from the 4 channel to the input on the monoblock everything seems whats bad about this is this fine do i lose anything or whats up +P
system :
4 chan: hifonics 60.4 ( db a7m 100.4 ) on the way
mono: DB pd2000.1 platinum
subs: 2 cadence s2w12's
HU: jvc kw-r500
mids: alpine type-R all around
thanks !
:twirl:
two of these on one set for the amp
edit: for mids highs amp
Use these from front channel to the the 4 channel amp. Then use the rear to the sub. Switch the rear channel to sub output. Thats what i would do. I believe running the rca from one amp to the other they would receive the same signal, as in they would see the same frequencies i believe. Not sure but hopefully someone would give you a better answer.
edit: but use the rca splitter with 2 male and 1 female that way you will not have to run another set of rca's
  • Who's Online   0 Members, 0 Anonymous, 2066 Guests (See full list)
