at half ohm with stout electrical youd see roughly 4k maybe a little less. so go from there
and thats with just one saz-3000 correct? how much do they cost?
Edited by ROBERT 04XBLZ
My New Build checklist:
(3) 18'' btl fully loaded d2
about 800, youd have to find a dealer though, they may be able to cut you a deal for less,
but there isnt any in stock at this time so youd have to find a used one
ok i just checked them out briefly and it says that its Linkable to another SAZ-3000D for up to 6000 watts @ 2 ohms so this setup would be good then. i can wire at two ohms just like my speakers would be and also go down to .5ohm... i think im starting to get it haha
3000 x 1 watts @ 1 ohm
1600 x 1 watts @ 2 ohms
800 x 1 watts @ 4 ohms
0.2v - 6v adjustable input sensitivity
10 Hz - 350 Hz Frequency Response
>90 dB S/N Ratio
4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
10 Hz - 60 Hz adjustable 24dB Subsonic Filter
0 - 180 degree adjustable phase shift
0 - 18 dB adjustable bass boost with 45 Hz center frequency
Wired Remote Control unit included
300-amp external fuse required (not included)
23.4" L x 9.9" W x 2" H
$1099 US Dollars - MSRP
if you already have D2's you could run each one on a single amp or both on 1 but again its pretty pricey and how much is the t3k you were looking at
what do you mean that there isnt any in stock :huh: everyone is out of stock or something??
i believe it was like 700-800. so for the price of the saz-3000 i would be getting almost the same amount as a t4k for half the price almost.
what it means is all of them are sold from the manufacture at the moment until the next batch is made
You could start with one @ 0.5ohm for around 4,000watts total then add another later. 6,000watts is what they're rated but I believe in the actual strapped test they made closer to 7,000watts.
so the numbers are max and not rms?
