Plankers_Pend Posted February 10, 2013 Report Posted February 10, 2013 I just ordered some KnuKonceptz Kord Ultra Flex 10 Gauge Speaker Wire, and while my amp is being repaired I am rewiring my subs down to 1 Ohm. Dual 1 ohm level 4's. The issue I am running into is trying to fit 2 of the wires into 1 push terminal just isnt working, its too thick for the terminal itself. How can I get around this issue? Will I need to use different wire, or is there an item similar to a Y connector that I can use to make this work? Sorry for the newby question, and my awesome Paint skills. Here is the terminals I am having issues with. http://i47.tinypic.com/2lkfvyh.gif Team DC! 2 12" Level 4 dual 1's 2200d
Carbon Posted February 10, 2013 Report Posted February 10, 2013 Cut, Strip jacket, Solder, Heatshrink. OR Reduce wire size. OR Use a modified ring terminal.
WastedTalent Posted February 10, 2013 Report Posted February 10, 2013 There are those adapters I think they're called. They reduce the size. Someone will chime in shortly I'm sure and give the name. But there's a way. Sheena = pedobear
Plankers_Pend Posted February 10, 2013 Author Report Posted February 10, 2013 After a little looking around, would something like this work? One wire coming in from the second sub, one wire going to the first subs connector, and the third wire going to the amp? http://www.wiringproducts.com/contents/media/y_connectors.jpg Team DC! 2 12" Level 4 dual 1's 2200d
Autruche Posted February 10, 2013 Report Posted February 10, 2013 Run wires from each terminal on each sub to individual terminals on the box. Do all of your coil configurations at the terminals outside the box. Much less of a PITA anyway. Just use nuts and bolts for terminals and you can easily change coil configurations without removing subs. There is no need to over-complicate this... Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Plankers_Pend Posted February 10, 2013 Author Report Posted February 10, 2013 Run wires from each terminal on each sub to individual terminals on the box. Do all of your coil configurations at the terminals outside the box. Much less of a PITA anyway. Just use nuts and bolts for terminals and you can easily change coil configurations without removing subs. There is no need to over-complicate this... Ah thank you. I have spent most of the day tearing my car apart to run wires in it and my brains fried rofl. I appreciate the advice from you guys. Team DC! 2 12" Level 4 dual 1's 2200d
