Zapco DSP6 and DRC
Package up for sale. All product is absolutely unused and in pristine condition.
$400.00 shipped anywhere in the con. U.S.
pics are from 2012. can take current with date if desired.
Someone buy this!!!!!!!
I also have the driver and software that enable you to tune via laptop that I will include in the purchase for even more tuning convenience.
Here is some info I copied form a web site that explains this way better than I can.
The DSP6-SL is a 6-Channel Digital Processor that provides Crossover,
Equalization, Q-Bass and Time Delay for each channel. The channels are
processed by six discrete processors which can be adjusted in stereo
pairs, or individually, to meet the demands of each installation. The
DSP6-SL uses three SymbiLink? connectors for the main analog inputs and
also has an optical digital input.
The DRC-SL does not come standard with the DSP6-SL, its is sold
seperately (THIS IS INCLUDED IN THIS SALE)
The unit is also DPN compatible so you can add it to a ZAPCO®
DC Reference system for even greater sound field control.
** Designed and Engineered in the USA **
Each ZAPCO DCS amp features a USB input. This allows a PC to be hooked directly to the amp to set all functions. All functions can be set as stereo pairs or as individual channels. These DSP functions include:
1 - Output and input Gain
2 - Input mode: Rt, Lft, or Sum Mono
3 - Crossover mode: High Pass, Low pass, Band Pass
4 - Crossover Slope from 6 - 24dB
5 - Q-Bass Equalization
6 - Network Node Position
7 - Time Delay by both time and distance
8 - 10 bands of Parametric Equalization per Channel
Also available, is a half DIN controller to allow the settings to be made from the drivers seat without a computer. (DRC)
This allows you to set all functions of all amps in a system right from
the driver's seat so you know how each adjustment affects the sound as
you make it.
