mmfr1 Posted February 13, 2013 Author Report Posted February 13, 2013 ^^^ I agree difinantly fix the problem you might not even have to spent that much I got my dc 3.5k new for less than the 2500 Their having a presale on them right now if you plan on upgrading what brand is dc....just getting back into this so learning all brands again
Ambassador of Bass Posted February 13, 2013 Report Posted February 13, 2013 13 amps O.O yikes hope you mean volts lol you are gonna need to crunch some #'sand see if a H/O alt or extra battery or if the big 3 is right for you. this well help...fix the distortion on what you have then....and only thenshould you upgrade if you even think you need to. Oh and make sure you use the right size wire and fuses along with good bare metal grounds...as short as possible Audi A6 Quattro Wangin' Wagon Pioneer Premier DEH-P5901B Headunit w/ IPOD control American Bass SQ5.25 in the Doors Compression Drivers and Horns under Dash 2 American Bass SQ475's for Mids/Highs4 American Bass HD 15's American Bass 500.1 17cuft 3/4" Double Baffle Birch Enclosure 240sqin port @38hz1/0 AWG Stinger big 3 under hood4 Runs of 1/0 AWG Stinger Power and Grounds Stinger Fuseblocks(3) XS Power D3100 Powercells120 amp AlternatorBlue Streetglow Underglow and Interior with Music InterfaceEscort Passport 8500 X50 HardwiredScanGuage II with voltage Readout
Noel989 Posted February 13, 2013 Report Posted February 13, 2013 ^^^ I agree difinantly fix the problem you might not even have to spent that much I got my dc 3.5k new for less than the 2500 Their having a presale on them right now if you plan on upgrading what brand is dc....just getting back into this so learning all brands again Dc audio/dc soundlab their just as good as any of the top underground brands Their a partner here go to the hope page and you'll se a banner click to go to their website Is their anyway you can check if the amp is good? Good grounds? Good rcas? Is it just distortion or can you here a hissing sound even when its not playing? Build Log - http://www.stevemead...-cruiser-el-pt/
mmfr1 Posted February 13, 2013 Author Report Posted February 13, 2013 13 amps O.O yikes hope you mean volts lol you are gonna need to crunch some #'s and see if a H/O alt or extra battery or if the big 3 is right for you. this well help...fix the distortion on what you have then....and only then should you upgrade if you even think you need to. Oh and make sure you use the right size wire and fuses along with good bare metal grounds...as short as possible yeah i meant volts lol. i have an extra battery too. my lights dont dim or anything and ive aleady done the big 3 before i even put the system in. my blazer caught fire and i had to replace all wiring so i did the big 3 while i was fixing. i will check out the video and see if i can fix it. thanks
mmfr1 Posted February 13, 2013 Author Report Posted February 13, 2013 ^^^ I agree difinantly fix the problem you might not even have to spent that much I got my dc 3.5k new for less than the 2500 Their having a presale on them right now if you plan on upgrading what brand is dc....just getting back into this so learning all brands again Dc audio/dc soundlab their just as good as any of the top underground brands Their a partner here go to the hope page and you'll se a banner click to go to their website Is their anyway you can check if the amp is good? Good grounds? Good rcas? Is it just distortion or can you here a hissing sound even when its not playing? ive checked everything but the rcas. they were brand new from american bass wiring kit. i have 4 gauge wire.....should i upgrade that?? stereo store said it was perfect for what i have and they hooked it up
Ambassador of Bass Posted February 13, 2013 Report Posted February 13, 2013 4 guage or 4awg? and is it a hissing or distorted sound like noelito asked? Audi A6 Quattro Wangin' Wagon Pioneer Premier DEH-P5901B Headunit w/ IPOD control American Bass SQ5.25 in the Doors Compression Drivers and Horns under Dash 2 American Bass SQ475's for Mids/Highs4 American Bass HD 15's American Bass 500.1 17cuft 3/4" Double Baffle Birch Enclosure 240sqin port @38hz1/0 AWG Stinger big 3 under hood4 Runs of 1/0 AWG Stinger Power and Grounds Stinger Fuseblocks(3) XS Power D3100 Powercells120 amp AlternatorBlue Streetglow Underglow and Interior with Music InterfaceEscort Passport 8500 X50 HardwiredScanGuage II with voltage Readout
mmfr1 Posted February 13, 2013 Author Report Posted February 13, 2013 4 gauge. no hissing just distorted when i try to turn the amp up and adjust x-over. my amp is only 1/4 the way up. i can listen to it at 49 on my pioneer without distorting but any higher then i get distortion which isnt the problem cause its loud enough but i think i should be able to turn everything up on the amp but i cant
Noel989 Posted February 13, 2013 Report Posted February 13, 2013 Where the gain is position doesn't matter Gain should match the preout voltage for maximum output or should not exceed the preout voltage So if you have high preout voltage your gain positioning will be low If you have low preout voltage your gain positioning will be high Lpf should be around 80-100hz Subsonic filter a few hz below tuning of box Eq/bass boost should be all the way down Build Log - http://www.stevemead...-cruiser-el-pt/
mmfr1 Posted February 13, 2013 Author Report Posted February 13, 2013 thats pretty damn close to where everything is. just dont know what the box is. i got from the stereo place pre built. so from everything ive read i should just stick with what i have and not spend the money on the sundown
Noel989 Posted February 13, 2013 Report Posted February 13, 2013 If everything is close then why do you think you should be able to turn it all the way up? And yea I would get evrerything straighten out first before you purchase an amp cause if you do A direct swap you'll have the same problem Unless theirs something wrong with the amp Build Log - http://www.stevemead...-cruiser-el-pt/
