I'll be going! I'll be in a red dodge stratus. I'll need to do a sweep, should I get there before everything starts or will there be time for me to do a sweep once things get going? (This is my first comp)
Also, when doing my sweep, do I need to be full tilt, or just enough to register on the meter? (Does the meter record the freq you peak at, or only the pressure?)
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
ive herd people say to only do do it at half volume..not sure why,maybe so you don't heat you're stuff up?
xbox 360 gamertag-greenrocks420
Not insulting you or anything, but did you just call us "bloody winging fairies" ?
Well I just sort of assumed that your peak at half tilt would still be your peak at full tilt. I just didn't want to be running a sweep and blow something in the process of going all out.
Do half to 3/4ths volume on a 35-50 sweep. You will prolly be around 34-44 that's where most people playing music daily tend to be... Your peak is your peak regardless of volume for the most part
Wrong. Peak is afected by volume
Do a sweep, find peak (1/2vol ish)
Then do 5hz up and 5hz down full tilt
My trunk peaked at 40hz on a sweep 148.x@40hz
At 46hz it did a 150.1
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Thanks for the info. Good to know. What was your trunk setup?
I'm in Cincinnati and I'm going to try to make it to the May show in Columbus. I've never been to show before. My car won't be ready by any means, I'm working on ordering my sound deadener stuff from Second Skin.
Currently, I'm running 1 - 12" Memphis M1 on a Directed 600d in a FoxBody Mustang. In progress of upgrading everything...
1995 grand am
5 batts
1 atomic 7k wired at 1ohm
2 pap wmd2 12s
Center slot port box with plugable port. Would burp a 50 and still kill 30hz!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
