Another Grounding Question.
Is it OK to run a ground wire to a seatbelt stud ? Or should i drill through the floor and to the frame ? Chevy pickup no back seat. If i could use the stud i can use about 6 inches of 0awg.
Thanks,
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
general rule of thumb is that seatbelt bolts are not good grounds you want to find a bolt or stud that is directly on the frame for the best grounds ... i dont know the reasoning behind it i just have always been told that seat belt bolts do not make good grounds ... and i always like to stay away from them and find good spot on the frame of the car.
  • Who's Online   0 Members, 0 Anonymous, 943 Guests (See full list)
