Are there any amplifiers that Doesn't split power?
EricDoody95
A mono block is an amp that just has one (mono) output. Mostly used for subs.
so they are for subs? and they do split power?
2003 Honda Element
Pioneer DEH-9400BT
Big 3
XS Power D5100
Sky High CCA (2 Runs 1/0 Gauge)
2 XS Power D3100s
1 DC Audio 3.5k @ 1ohm.
2 DC Level 4's w/ XL Softies
Custom Box tuned to 29hz
CT Sounds 125.4
2 Sets of CT sounds Meso Components
*North East Frequencies*
An amp is only going to do what you tell it to. If you want to power 2 subs with one amp you can. You can power 10 subs with one amp, it doesn't matter. You can also wire 2 amps to a single sub.
It all just depends on how you wire it.
If you correctly wire an amp to 2 or more subs yes it will split the power evenly between the speakers.
I guess they don't have to be for subs but I've never seen someone run a monoblock for their door. They are used for subs yes.
Ahhhh so what kid of amp would u reccomend for two SA-12's? budget = 400
2003 Honda Element
Pioneer DEH-9400BT
Big 3
XS Power D5100
2 XS Power D3100s
CT Sounds 125.4
Just stick to the recommended rms so get 1200-1500 rms .. The subs can take more than that but u need to know what it takes to take to put that much power on those
I had 2 sa 12s on a AQ1200 and it powered them.very good..deff in your budget to!
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
