DubNDodge Posted March 1, 2013 Author Report Posted March 1, 2013 Awwww yeahhhhhh!!!! A great thing to come home to! '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DubNDodge Posted March 3, 2013 Author Report Posted March 3, 2013 Got some more stuffs done. I got the passenger side of the wires ran back. (RCA's and right speaker wires) After that I got everything cleaned up. I put techflex on a whole group of wires that would go into the trunk. (Driver side was the power and vm wires) (Passenger side was all speakers wires and RCA's) That way when I go to great foam that gap up, the wires won't get all crappy. Plus it keeps them all nice and neat going into the trunk. I knew there is some kind of sticky backed zip tie for this situation, but I said screw it, electrical tape will work... Passenger side Drivers side I then started working on the battery rack. I made a cardboard cut out of the max flat area I had in the spare tire well. I then got side tracked and was trying to figure out how the amps would work out. I had three options basically. first cons: Mounting and looks meh second cons: mounting, tight fit, wiring will look a bit sloppy the third was to have them stacked in front of the battery. the con there was that if I needed to adjust a setting I would have to take an amp out. so I said screw that. I will end up going with the second option probably. I started on the battery rack again. I angled the bottom so it would fit more snug. Got it to fit on the first try ftw! I also traced the battery to mock the rack up. Nice 'n' snug - it was all screwed in from the bottom/back. It isn't glued yet. I went to get the damn thing out and it wasn't coming out without me doing this and shaking it a bit so I could get the handle. I also will not be gluing the small front pieces of the battery rack, and will be screwing them from the top, so that if there ever is a problem with the batt, I would have to rip out the whole box and everything just to get the bat out. I am extremely impressed with the handle on the d3100. It's hard to believe that how small it is could support 75lbs. I was waiting for it to snap when I was walking up stairs with it and it didn't. I could feel it flex a bit, but nothing near of what I thought it to be. It blew my mind. Also, needless to say I got a great work out putting in and lifting out that heavy sob from the trunk. It sure did man handle my skinny ass. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
ccmotox99 Posted March 3, 2013 Report Posted March 3, 2013 looks good. I like where the build is going and i love seeing audioque! Too bad they switched the name to soundqubed -playing with different setups
DubNDodge Posted March 3, 2013 Author Report Posted March 3, 2013 Thanks! Yeah, wish they didn't change their name, but oh well. I will just have to be careful not to pop a woofer, I rather have all AQ logo'd equipement '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DubNDodge Posted March 4, 2013 Author Report Posted March 4, 2013 Finally got the deck carpeting off today. Lot more holes in it than I expected. Tomorrow I will be fabbing up some mdf or some kind of adapter to cover up 6x9 holes. 3/4" might be too tall. If you had 14sq ft of deadener, where would you say the big spots to get are? sheets are 2sqft I was thinking 1 sheet for each front door 1 for rear deck 2 for roof Edit: not sure of the other 2 '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DubNDodge Posted March 6, 2013 Author Report Posted March 6, 2013 Got the mdf covers made up, but first I worked on the box a bit today. I got the screw holes predrilled for the side beauty panels. Both sides are predrilled. I did some practicing on a scrap piece of wood to make sure I would be able to make the holes snug enough on the speaker wire for the subs. It's 8ga speaker wire. Repeating that on the box. Smacked the screw with a hammer to leave an indent for the bit to get started on, so that it didn't squirrel around on the mdf. Used a smaller drill bit so that it would guide the larger one and so that it wouldn't feel the need to pop into the other hole. Bam! I will be caulking when the actual wire goes in. Here's the mdf speaker hole cover. I just traced the speaker onto a piece of mdf and then used a band saw to cut it out. It was the scrap from the cut out of the baffle Here's how its gonna be sealed. Thanks for SlamminBeats for showing me this stuff. It's also the stuff I will be using around the side beauty panels of the box. Drove the screws straight through the center of the foam rope. Got it snug, and lined all the rope up. Then I really torqued it down. Sure did squeeze out. I will be snipping those screws off later. Don't want to risk scratching the amps. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
pimpnFosgates Posted March 6, 2013 Report Posted March 6, 2013 Good work buddy Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Twostrokeking Posted March 6, 2013 Report Posted March 6, 2013 That caulk rope is cool!! Nice build man My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
DubNDodge Posted March 6, 2013 Author Report Posted March 6, 2013 Well I spray painted the inside of the box today. Ended up not liking how the paint was glossy on the glue spots, so I ended up sanding it back down and putting primer on. Which I should have done in the first place. Oh well. Sanded and primerd the port. Started cutting the carpet for the box, it will have to be put on the box once it's in the trunk, will be a challenge. I put the battery rack in the trunk permanently. Pretty much broke the camera because it was in my pocket when I went to put that heavy ass battery in. I fixed it and will get more pictures of it later. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DubNDodge Posted March 7, 2013 Author Report Posted March 7, 2013 Here's the picture of the battery rack. The white stuff is wood glue. I was going to glue those two pieces in, but then decided if I ever had to remove the battery, it would be a huge pita. Now I can just unscrew those pieces, and bend the metal piece. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
