Learn a Noob Something
So, looking at picking up a new battery. Mine seems to be dieing in my new car. Obviously thinking about picking up a nicer battery such as the SX D2400 so I can build out a descent system. Going to use as the primary battery so it claims it can supply 2500 watts. What I dont really understand, excuse my noobness, is the relationship between the output of the alternator and the input of the battery.
I understand that on a DC current you can basically take AMPS * Volts = Watts. So if I have a 110Amp alternator at 12 volts that results in 1320 watts.
So say I ran a 2000 watt system, the battery could keep up in terms of power output, but the alternator could not keep-up to charge the battery correct?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
If you ran full tilt for a long period of time eventually the battery would die and stop picking up the slack, yes. Unless you are at intersections banging hard 24/7 you shouldn't have much to worry about and the battery should charge when there isn't too much of a load on your alternator like when you have the volume down or the bass isn't hitting.
I'm gonna hate
  • Who's Online   0 Members, 0 Anonymous, 822 Guests (See full list)
