dimming lights
Oh yea lol the big 3, bigger alternator, but if u do the big 3 I noticed with my truck it made a huge difference doing the big 3 with audio technix 0 gauge OFC cable .. Cca just wasn't as good in stopping dimming
Lights dimming will almost always happen. But it sounds like they are dimming a LOT, indicating lack of current flow or just not enough juice to supply. Do the big three upgrade (You can find out how in the electrical section IIRC) And then maybe some batteries and possibly a H/O Alt. Do the big 3 and go from there. Check your voltage though, don't just do all this stuff simply because your lights are dimming.
I don't even drop .1 volt at 2k rpm and my lights still dim when the bass hits.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Just as they said, do the big 3 with 1/0 with OFC check it their, if that Dosent help too much consider getting another battery (and check the battery you have now) still Dosent work a ho alt should fix it, maybe post up what you have to give everyone an idea of what you got
(On mobile so can't see Sig)
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
upgrade to the big 3
2003 Honda Element
Pioneer DEH-9400BT
Big 3
XS Power D5100
Sky High CCA (2 Runs 1/0 Gauge)
2 XS Power D3100s
1 DC Audio 3.5k @ 1ohm.
2 DC Level 4's w/ XL Softies
Custom Box tuned to 29hz
CT Sounds 125.4
2 Sets of CT sounds Meso Components
*North East Frequencies*
  • Who's Online   0 Members, 0 Anonymous, 1026 Guests (See full list)
