5 Tantric HD15s, PRV, Singer, Team Turbulence !!!
  • 4 weeks later...
Nice to see someone actually consider this type of box from a qw perspective, rather than an obscure ported box.
Add a tapering to the inner chameber "furter to the backwall" to 'let it approach looking like a port', and a loading wall, u could probably model this as a 6th order quasi.
As far as this goes now, I'm pretty darn excited :)
if you want to "elaborate" with this finished product, u could build an insert behind the woofers (to the side walls) to cut that space in half, ie like this http://imgur.com/bGGSAui
if u'd care to model that out in horn resp u'll find a higher compression, giving some leverage to output (as usual - at cost of bandwidth/response).
then the design can be seen as a not only as a qwpipe, but a tapped horn.
anyways, cheers
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
or flare/curve the back end where it enters to the port
Hammerdown... 1%
