Rmichael91 Posted February 21, 2013 Report Posted February 21, 2013 I've got a 2008 Chevy Aveo Ls with a 1.6L 4cyl. I found a 170amp high output alt through Singer, biggest that can fit stock in my car. I've checked the website for battery fitment and it came back to a D4800 for under the hood. I'm doing a build using all Skar Audio amps. Right not the builds planned out and going through with an Sk85.4 for mids and highs, picking up another for another set of doors and kicks. If I don't upgrade over to the 125.4s. Subs for the time being, sk2500 on two zvx12s at either .5 or 1ohm, haven't decided between d1 or d2 woofers yet. With the d4800 under the hood, I was planning on two S975s in the trunk as the rear battery bank. But if I can get further reliable and stable power with different options I'm open to them. Of course the big 3s getting done, I don't intend on playing off the batteries for long periods of time, and an intellichargers gonna get tossed in as well. I already talked to Jeff about this a while back, just wondering what other options anyone could throw my way. Quote
Nathan @ XSpower Posted February 21, 2013 Report Posted February 21, 2013 Instead of running the two smaller batteries you could run one bigger battery for probably the same money if not more. Quote
Rmichael91 Posted February 21, 2013 Author Report Posted February 21, 2013 I was going to utilize the wheel well for the spare for my battery bank, I knew those 2 would fit as is. But what would you suggest Nathan? Down the road I'm moving to the Sk4500 or adding another sk2500. Quote
Nathan @ XSpower Posted February 22, 2013 Report Posted February 22, 2013 If you are going to jump up in power like that, then I would suggest the XP3000, D3100, or D7500 options. Quote
Rmichael91 Posted February 24, 2013 Author Report Posted February 24, 2013 I'll do a little bit of measuring and look into it. I jumped back on the site a bit ago today and re ran the "What fits your vehicle" and came up with the d3100, 5100, and 5100r. I guess you guys did a database update since the last time I looked into it? Quote
