Box Design
dl9890
Ok what would be the max dims for the box, amp model using, and what use, daily or just output, type of music.
Give or take:
Height: 17.5"
Width: 34"
Length: 32"
Trunk opening is roughly 20"
I'll temporarily be using a DX1000.1 (Changing soon) And it will be a daily.
May need to build a cardboard dummy box to test fit and also try fitting by removing your backseats:
Enclosure Specifications:
Fb = 36 Hz
Vb = 4 ft^3
External Height = 17.25 in
External Width = 21.5 in
External Depth = 30.75 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 21 1/2 x 17 1/4
Left & Right Sides = 28 1/2 x 15 3/4
Top & Bottom = 21 1/2 x 28 1/2
L Port Internal Assembly Parts:
Front to Back = 23 x 15 3/4
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
  • Who's Online   2 Members, 0 Anonymous, 1598 Guests (See full list)
