beaker Posted February 23, 2013 Report Posted February 23, 2013 1) Price point This one is kinda obvious, but I'll get into the rest in a moment. ATI and Nvidia have a bit of a war going on this front. AMD is a better bang for your buck, but you may end up pulling your hair out trying to get it stable. A comparable Nvidia card will be 100$ more, but for the most part, are wildly more stable. 2) Use If you're just trying to make Windows go a little faster from a dedicated card, this is a bit different than running 3 Monitors maxxed out. Cards for rendering are a lot different than cards for gaming. Yes, the card may have 8 gigs of video ram, but it was designed to render scenes and add visual effects, not play the latest DX12 titles. Some cards also scale better in SLI and Crossfire for multi monitor configs. Usually these are the ones with more of #3 3) Memory Bandwith This is a HUGE deal.Why is that 660 a 660 and not a 670, or 680? One of the major reasons is memory bandwith. This is one of the most commonly overlooked specs when buying a video card.There is a reason that a 480 will still out preform some newer cards. The memory bandwith is 384 bit, which makes the fill rate a LOT higher. 128 bit is the lowest I would go for anything that is gaming related, and even that is pushing it. Though if you're just doing rendering, this makes less of a difference since it doesnt need to be real time. The 660 Ti makes up for it with higher clock speeds and lower power comsumption, but as you get into more Anti-Aliasing and Higher resolutions, you're going to want that bandwith. Thats about it. I also look at warranty, as some companies will even cover overclocking damage. Again, this will cost more, but you get what you pay for.
teamjeffrey Posted March 5, 2013 Report Posted March 5, 2013 that's some pretty cool info idk if this can help to your topic and sorry if i thread jack and also but this site tells you which video cards are high end mid in low end and which ones are the best bang for the buck and other stuff http://www.videocardbenchmark.net/index.php people who have bought from me Team Bassick (ALPINE) Purplehaze nidus head unit sony dsx-s310btxsubs 2 12 incriminator audio king of basssubs amp incriminator audio 20.1mids/highs mids/highs amp incriminator audio 6.4equalizer clarioncrossover interfirealternator 1 mechman 240ampbattery's xs power 1 d2100 2 d3100sky high car audio 1/0 awg ofc wires memphis car audio 1/0 ofcxs power xs flex 4 awg sky high car audio 8 gauge ofc sky high car audio 12 gauge ofc t spec rca check out my building log http://www.stevemead...frey-build-log/http://www.stevemead...d-other-things/check out audio gear i have for salehttp://www.stevemead...51#entry1595151
beaker Posted March 7, 2013 Author Report Posted March 7, 2013 I'm not sure how legit that site is . . . some of the price data is wayyy off.
STEvil Posted July 12, 2013 Report Posted July 12, 2013 Memory bandwidth is an issue, sure, but you're leaving out computational performance due to disabled parts ("cuda cores") on those same mentioned parts. If you cant do the math on the scene there's no race to the pool edit i'd use hwbot.org to guage performance vs price probably MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
