What amp to put with cresendo mids & highs
basshead5280
So I'm planning on getting some cresendos PWXs probably 6.5s about 2 in both front doors and then probably 1 FT-1 super tweeter in each door. So 1 tweeter each door. What amps should I get for the 6.5s and tweeters? If need be maybe 2 tweeters in each door? What do you guys think?
Sub stage will be 2 15" dc level 3s on a dc 2k
1999 Durango
Current
2 15" DC level 3 15s
kenwood HU
Cresendo bc2000
Big 3 upgrade
Sky high car audio wire
Coming soon
Cresendo c1100.4
double din
New Build log
http://www.stevemeadedesigns.com/board/topic/168661-99-durango-dc-audio-package-in-and-box-almost-done/?p=2464991
Clean Build log
http://www.stevemeadedesigns.com/board/topic/171619-dc-audio-durango-clean-build/
Ok I was thinking the same thing. What's the output on each channel?
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
at 13.8v
4 x 180w @ 4ohm
4 x 300w @ 2ohm
2 x 600w @ 4ohm Bridged
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Ok sweet thanks. What about the tweets? What amp should I get for those?
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
Well, if you're running just on the front doors, I say the C1100.4 can power all of them
Like you use channel 1&2 for the tweeters, and channel 3&4 for the 2 6.5's and run active.
2003 Kia Sorento
Team Subsonic Lows
1 tweet per door is plenty. If you have the cash get a c1100.4
I agree those things are loud! Get the C1600.2 for the mids and the Soundstream ref2.370 and run the tweets at 8ohm for super clean highs
1 c1100.4 will be sufficient no need to run 2 amps.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Im planning on running 4 ft1s and 4pwx 6.5s on 2 soundstream 580.4s (for now)
Ok so I'm debating on the 1100.4 or the dc 175.4. Mainly want to do the dc tho. What tweeter should I get the 4 or 8 ohm? And how would I wire them together? I'll get the crossovers from cresendo also.
Oh and is it ok to run channel 1&2 at 4ohms. Then channel 3&4 at 2ohms?
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
  • Who's Online   0 Members, 0 Anonymous, 1100 Guests (See full list)
