villarob713 Posted February 24, 2013 Report Posted February 24, 2013 Should i go with another cvx or some xs batterys or another hifonics plz help me out Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
jhmeg2 Posted February 24, 2013 Report Posted February 24, 2013 need more info, otherwise add a cap. ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
villarob713 Posted February 24, 2013 Author Report Posted February 24, 2013 I got to 15 inch cvxs dual coil on a 1500 class d hifonics. Running off a stock batt and alt. 0g wiring its pretty loud but i want more. They deck is also stock with a rca converter Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
villarob713 Posted February 25, 2013 Author Report Posted February 25, 2013 ??!?? Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
Swordlordboy1234 Posted February 25, 2013 Report Posted February 25, 2013 you still give no info. what is your voltage drop? what is your nominal ohm load? what model amp? what kinda box? how did you set your gains? do you have big 3 done? any good wires? OFC wires? CCA wires? Stock deck could be hurting you too. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
djscrappydee Posted February 25, 2013 Report Posted February 25, 2013 buy a new headunit (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
Carbon Posted February 25, 2013 Report Posted February 25, 2013 I would add a headunit, Add a cap, Or change the sub out.
CleanSierra Posted February 25, 2013 Report Posted February 25, 2013 Stop looking at cheapass amps for starters. The SSL and BAMF are garbage. Who built your box, there is step one to getting louder and cleaner. Im not the one you want to try to troll. Just a fyi for you.
villarob713 Posted February 25, 2013 Author Report Posted February 25, 2013 Idk what it drops to. My lights dim pretty bad i got a new unit just havent installed it yet. 15s are wired at 1 ohm Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
villarob713 Posted February 25, 2013 Author Report Posted February 25, 2013 Whats wrong with my subs? Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
