agm charger
Since i cannot afford the intelli charger i went with a dofferent one. Its 1.1 amps and starts at i believe 12.6 volts and slowly goes up to 14.7. Is this correct or should the voltage be at 14.7 all the time? I guess im asking how a charger is suppose to charge these batteries amd other batteries. And is mine correct?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
How is a charger suppose to charge batteries?
Need a diff charger. I was in the same position as you. Walmart sells chargers in the battery section. I bought the Schumacher charger. Was like $60. Has 15 amp charging capability for lead acid, gel, and AGM. I hear you should use 15 amp charge to charge your batts.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
But is the voltage correct or should it be at 14.7 constantly or does it work its way up?
Dont know. Cant tell you. But what i can tell you ia that 1.1 amp charge rate is not enough. Thats basically just maintaining your battery.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
I use the Battery Tender Plus. It has 3 steps it goes through. Bulk charge, which charges the battery up to 80% it charges at 15.0. Once it hits 80% it drops down to 14.3 until it is 100% charged. Once it is 100% it maintains it at 100% at 13.4. It is a 1.5A charger. My D925 rested at 12.7 before using it, now it rests at 13.1 after using the charger on it every other week.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
See isnt that amperage too small^? But that sounds good. I should look into it
I remember XS posting somewhere that you really don't want to go over a max amperage of 4A and don't go over 14.4, but I am assuming 15.0 won't make my D925 gas too much.
If you plan on letting your battery trickle charge (keeping it topped off) you don't want a real high amperage.
Ok do you know if the charger needs to hold the voltage about a certain point or does it work its way up. I will look into that charger.
  • Who's Online   0 Members, 0 Anonymous, 990 Guests (See full list)
