Ported box for 2 sa-10s in a 2002 mustang trunk
SoImVan
At first I wanted to go with 12s, but i feel like getting 12s in my trunk would be a bit of a squeeze. I have decided on 10s. Anyone have any info on some ported box specs that would work for the sundown sa-10s?
Here is a suggestion to work on rated power:
Enclosure Specifications:
Fb = 34 Hz
Vb = 2.4 ft^3
External Height = 12 in
External Width = 33.5 in
External Depth = 18 in
Port Width = 2 7/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 33 1/2 x 12
Left & Right Sides = 16 1/2 x 10 1/2
Top & Bottom = 33 1/2 x 16 1/2
Shared Port Internal Assembly Parts:
2 x Front to Back = 15 1/16 x 10 1/2
2 x Extension = 4 5/16 x 10 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 2 7/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Thank you Joe. I know we've discussed this before. This box plan seems to be an easy fit as well as a great design. Thanks again for the help.
Ok man, if you end up doing this with the 45s inside the port, let me know to give you some infos on how to do them.
Will the design be the same if i dont do them?
Seen many boxes perform well without them so it's up to you, if you end up doing them just do them as follows:
  • 1 month later...
Fb = 34 Hz
Vb = 2.4 ft^3
Cut Sheet List:
Important notes:
Hi Joe. Would it be too much of a problem to maybe adjust or make a box plan that is similar to this box designed for two American Bass TNT 10s? They lean more towards my budget. Help would be extremely appreciated. Thanks.
The subs are very similar and the same box can be used for the TNT 1044s but the SA10s have greater Xmax and therefore will be harder to bottom out and likely will handle more power. The TNTs should used with caution above rated power. Subsonic filter to about 30Hz. 0.1 cubes/sub of driver displacement was estimated for the ABs (same as the Sundowns) since the don't list that info.
  • Who's Online   1 Member, 0 Anonymous, 10142 Guests (See full list)
