XS Power
Anyone here owns an Expo??? Is there any way to make a Powermaster fit under the hood? I'm sure I'd have to mod it.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
to me if it fits perfect, its too small :D
try and find a way to get a D3100 up front even if you have to mod a few things.....its WELL worth it. I know i put a 2150 in that 05 Navigator i did so it shouldnt be too much different then an Expo right? Isnt a Navigator to an Expo what a Escalade is to a Tahoe? Same car just fancier?
Follow my Tweet (Twitter)
Yes they are basically one and the same. A guy I was stationed with had 2 red tops under the hook of his expy. However, he had to remove the windshield wiper reservoir. I'll take a pic of under the hook tomorrow and hopefully you guys can give me some pointers. Hell 1 D3100 trumps both my yellow tops.
  • 3 months later...
I agree with Steve, of course ... you can never have enough reserve power. So, squeeze in what you can. But, if you have the common 6 cell group34 yellowtops now. . The D3400 is group 34 also, of course. So, it will take the place of the optima without any issues. It also happens to be the size that would fit with a little room to spair anway. So, you could drop it right in, and add another to the back to replace the other optima and be covered for about 6000watts or so combined. They are much stronger than the yellowtops.
But, if you want to pack all that you can under the hood. . as long as you have another inch or so to spare in height you can run with the D2400 no issues. The D2700 will require that same additional height and another inch in length. . The D3100 would require two extra inches in length and the same additional inch in height.
D3100 should be about 13"L x 7"W x 8.5"H (est.)
What are you running for amps?
My amps are in the sig. Also check out D3100 in Expo
