Singer 220A H/O alt
I did the recone, I think it turned out very nicely
this is one beefy bastard
I cleaned up my lights with toothpaste and it made a BIG difference
Then back to the recone!!! there was white paint on the gluing surface so the dust cap popped off and failed at the paint. to fix it I sanded the gluing surface and used some shoe goop to put it on again. It's looking super sexy now
This is where I am at now, I still need to seal off the trunk but I'll just wait until I am un-butthurt and I have more money to throw around
I also got bored the other day and bought some plastidip to do certain parts of the car. It doesn't look bad, but it isn't good.... if that makes any sense lol
I was able to get a couple vids up showing the excursion and a little flex
Another video
nothing big lately. I get my alt soon. I wrapped the back side of my box today, it turned out great IMO for my first time wrapping
563508CB-4280-44FC-BCC5-D0FFBD54163A-441
45001460-5EB2-476C-8D84-CBA9A43CC3B3-441
61A384BD-3035-4279-97FA-D84D5104606E-441
Lookie what I got today...
ED36BC6A-176F-4A32-B462-10C6A5DF0941-844
1FEB9552-04C8-4839-9C58-96DEAE4D2BBE-844
He included quite a few "Ginger Alternator" stickers too :peepwall:
51E5D830-2DB7-4507-A6D5-314464C1C34C-844
This big lip on the HO alt is obstructing the alt from going on and in turn causing the pulley to seize up due to pressure on its insides or torsion. So I need to grind it down and try again.
6C87C0F1-5B93-47C8-8E7B-EC2D19EE782C-895
And my sub... My shitty solder job came off so I went to get direct leads done instead of push terminals. Well we tested the impedance of both sides which should have been 1ohm but one side said .2ohms. The coil was a nice honey gold color except for one spot close to the coil to tinsel lead connection where it was black. My guess is that when we did the recone one of the terminals broke so we had to solder it back on. We soldered it or a long time and applied a lot of heat. We think that the heating caused the resin stuff in the coil to become more brittle and yada yada. It's hard to tell what happened because it's only that one spot where it's bad. Gains were set right and I never took it above where gains were set.
And some demos...
Some more progress!!! TRUNK BATTERY!!!
FB9DD5C5-3E28-433D-BCF9-18A754C6940B-735
It's a rats nest. I don't care now. I'll clean it up and make a proper system of keeping the battery in place as well as wire organization :)
Also I got my trophy in the mail :)
0AAE73EF-B3B3-47A0-BEBF-022950E05C81-834
I'm having issues either with my RCA connection at the amp or RCA connections internally in the amp. I'm going to investigate before I invest in a new set of RCAs.
blue illuminated cup holders!!!
1D91ED98-DEF3-478D-B21D-4AF3D99EDBA3-316
0B98CA7A-E01E-4B1F-B1E9-D4F81F4AA2ED-214
25FF17DF-B0B0-48E1-8C87-E3C391B1FEC7-214
It turns out that the sub reaches it's mechanical limits when playing 45hz test tone for competition so I can't go until clipping stops on the HU :(
In recent updates I switched out the positive 4 ga with 1/0 that I got for $20 and rounded over the port exit to eliminate port noise so nothing really photo worthy
ooh what is this?
E45EB85F-4321-4136-9237-0E311796E649-217
2D0A5567-00D8-4AA3-AE7F-ACAF5530528B-306
80B72FCF-74A1-4E46-A5F7-54984DA5B93C-306
there will be some fiberglassing right here
81E346BB-4374-4914-8FF3-175A9A7D4A17-306
A few ideas thrown around...
B3BFBC6C-485D-4222-85D7-F9B3DE0D26CD-656
FE5363C4-83BD-4209-8715-5749116B33B0-656
22CAF4AB-4089-4615-87A5-24174B150E02-656
DBE79D6D-C81D-46C9-A080-2916A85572AB-656
All wrapped up
3A7BBECA-0439-4188-A6F7-46DCDEB21A46-656
D145A5DA-66C1-4B17-B9DD-25918079F5FF-656
Resined and test fit to prove that it works
F9D8D53F-7C7D-4405-A15A-0574A5C077F5-656
1CC75FD5-0197-4B8A-8B79-4D7556953A0E-656
C83DB4B2-BDFF-4A08-BE05-C9DDA63B53E6-656
8F37EDC2-A4FB-4C97-8BAB-093DB5A740F2-656
Skipped fiberglass photos because my fiberglassing sucks :P so here is fiberglass and filler
1428372C-D8A9-46EC-907F-D142110114BC-656
921C8DFF-AC04-49C0-8502-E5E8AAFE245B-656
goddamn. started applying filler primer and I messed up so I had to fix it and I'm still in the process of fixing it... moral of the story is don't touch wet paint
C12BC539-FC5A-4153-8B94-4C71A74EFA7B-230
and a little mock up :)
64B7A9ED-04F5-4471-AEBA-51A2E8375BE8-230
Final coat
446EDDDB-F19E-4975-90C3-83297D239C68-348
loaded and last coat of paint
8C416D61-55CC-484C-BA10-183D37C6F91F-348
AB06F2E7-F7DA-46DD-9006-B35FDF7B5A93-348
Also just started tweeter pods
B5DB7E4E-3021-4910-8DC5-9C964540FA07-348
1394BA34-A0AB-48FC-AE4D-026778EF5C5D-348
Tweeter pods resined. Next is fiberglass :(
0F2C74BD-42FE-40ED-95F2-8D921ACFFF9C-873
Some more progress. I need speaker wire still so they aren't wired up. I put them in the door and fastened them in with a few screws. Excuse the dirty car :P
EAE26E4A-F60E-4742-A2A5-8D30A39C86C5-345
DBFF9BE5-9024-4CF6-A68E-CF1B281AA48E-345
got into a little accident on snowy roads :(
before accident
little accident
35B00619-54B5-4A08-BAE8-ED513E65A14B-177
fixed!!!
0518A49D-09FD-4000-B19D-93228F30161A-852
BLUE
D016085E-7342-4684-BA6A-A5ED7FD8C851-240
It's not done yet, I still need to make trim rings to go around the crossovers
Fiberglassing sucks dick, what a mess to work with
just for teh lulz...
snow has been shitty, so I haven't had a lot of motivation to get a lot of work done in the car
tweeters filled in with filler and sanded down nice and smooth
primer filler
test fit
both done
test fit black
tweeters in
INSTALLED!!! :D couldn't be happier with how the tweeter pods turned out
I got the drive door pod filled in and sanded. this one was a huge bitch because I had a lot of fiberglass bubbles..... oops
primered
My girlfriend got me the PAC-LC1 for Christmas and I just go around to installing it. the sundown remote gain knob was freaking out and sending the amp weird signals and it scared me every time I adjusted the gain with the knob
I have the drive pod painted and all, I just haven't had the time to install it with this week being so busy. I'll have it installed hopefully during spring break
Just bought an older RF amp off of one of the members here, I forget what their screen name is though
54779354-2C11-44F2-B1F2-DA5D5112D933-625
I just took the end caps off lol. they take up too much space under my seat
everything I need to install the new amp
4D69076C-4023-45DC-A3B6-5C5EF005719E-625
removed driver seat and first thing I did was grind down a good ground
9A9F3025-F1B4-4660-A9B8-7DF72F4D2D77-625
everything in and wired up, except for left speakers of course
D2730ED5-76A1-4840-B1FA-B1AA230C412A-625
4FCD86AB-DAB1-4FD5-A3B2-C6CDD6DC4300-625
so far they sound good, I want to wait until I can get an O-scope on the amp so I know where I can turn it up to
D00B8A09-249D-43C1-B738-30A14E97A9BD-625
not pretty but it works
9E41E1CC-F6F1-4C2B-8115-6C5A9617DEAF-625
this was very helpful for cutting the tweeter hole
39AD65EB-9FA4-48FA-A1A1-DE100460D828-625
and some video for you video whores
I still need to upload more, this video was just on stock HU power. I can't wait to hear them scream when the amp is tuned properly. I love how the highs sound already and how they sound in general with live music :)
so spring break was this past week. Instead of going out and raging I decided to go home and work on my car :)
first of all I got the mids/highs amp mounted above the ground with some UHMW plastic strips that I found laying around the house
9676D22D-AFB7-414A-8432-9E00E967E4D7-138
3FCE6D9A-CFF4-4570-A94F-0FD187789BA8-138
I got wires cleaned up too and hidden
31D7B2EC-8617-41F6-ADF5-147BC1FF4540-138
I dreaded doing this, but I got up the courage to get my shit together and work on the beauty panel for the trunk wall
got a paper template made up and with taped sheets of paper
654D1B80-9A5A-40E3-A916-64C19DCA1821-138
after 2 tries I finally got a whole sheet of 1/4" birch ply cut in one piece lol
1EE36C3E-C5CF-437D-972D-8EDB02921B54-138
BINGO!!!
05D8FAB6-881F-4198-972C-E95270E66B43-138
what could this be?
049B0D76-A699-4177-8EC7-D12BA5126BAE-511
  • Who's Online   1 Member, 0 Anonymous, 2287 Guests (See full list)
