ZAPCO209 Posted March 1, 2013 Report Posted March 1, 2013 Need battery recomendation for 02 tahoe, gonna be runnin two reference 1000s any help appreciated Quote THE DRIVING FORCE
ToNasty Posted March 1, 2013 Report Posted March 1, 2013 xs d3400 Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ZAPCO209 Posted March 1, 2013 Author Report Posted March 1, 2013 Will it fit under hood with no modds? Quote THE DRIVING FORCE
AA98hoe Posted March 1, 2013 Report Posted March 1, 2013 Should then I'd put a 3100 in the back an a good alternator .. Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
ZAPCO209 Posted March 1, 2013 Author Report Posted March 1, 2013 Thanks for help, what size alt will i need, also gonna have a 500 watt ecljpse amp for highs Quote THE DRIVING FORCE
AA98hoe Posted March 1, 2013 Report Posted March 1, 2013 I'd do at least a 270 from mechman Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Nathan @ XSpower Posted March 5, 2013 Report Posted March 5, 2013 If you are running side posts still you will want to go with a 551 or 555 iBar kit as well. Quote
