ummm help, please?
Fuzz
I would like to run a pair of Cerwin Vega pro 6.5" mids in the rear dors of my truck. I have a 4x75@4ohm/4x125@2ohm amp.
Now these speakers are rated up to 100 watt rms and I am sure the 75 I can offer will suffice. However lets say I am not satisfied and would like to add a set of Cerwin Vega pro 1" tweters which are rated at 50 watts rms. Will I have enough power to run these on the same channel with the mids? (I know there are other options as far as brands go, but I have already made my decision with these so please don't bother with the suggestions.)
And how should I connect them to the amp?
They are both 4 ohm speakers, but can I safely run a 2 ohm load to them?
I must be over thinking this because my brain feels like it's being pulled apart.
What I am thinking is I can run from the amp to the mid and the mid to the tweeter (these have built in crossover) matching all polarity. Is this called Paralell or Series?
That idea is no bueno. You need to keep them on seperate channels or use a passive x-over that you can hook both of them up to then to the amp
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
Are you bridging the 4ch amp down to 2ch? The minimal load is 4ohms after bridging. Unless the manufactuer says that the 4ch amp is
stable at 1ohm on all 4 channels. If they dont specify it. I wouldn't chance damaging it and could void any warrantee if you got it.. The other way
is clearly well said by TheScottishBear.
MY BUILD LOG>>>> NAH I BETTER NOT..
Not bridging it, I have the front channel hooked up to a pair of components. I just want more volume from the rear so I want to go with the high out piut mid drivers. But I am wondering about maybe later on adding the tweeters.
I figure setting the amp at 100hrtz highpass should work for the mid range drivers. These particular tweeters have built in crossovers, so I don't understand why I would need anything else.
I guess my question really is, can I run a 4 channel amp with the front channel at 4 ohms and the rear at 2 ohms?
  • Who's Online   0 Members, 0 Anonymous, 809 Guests (See full list)
