96 Acura Integra LS - Throttle go CRAZY!!! Help
So today I got on the freeway and suddenly my throttle just go crazy. My engine sounded like it was going to explode and saw my RPM was at red line. I quickly put it on neutral and still having the same issue so i put my hazard lights on and shut off my engine while my car is still rolling. Then start my engine again only to see my engine rev'd up by itself still so i pulled out of the freeway (car still rolling with no car behind me).
Came to a stop check throttle, engine, etc and no sign of cause. Throttle seems fine, no CEL, nothing. Started engine and drives normal. Went back on the freeway and same shit happened... WTF?!?!? Pulled over and come to a complete stop, turn engine off then on again and drive to the next exit and it works fine. Been on city streets with no issues.
Any ideas?
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Have you checked out your throttle body? There's got to be something holding the butterfly open. Either the throttle cable itself is getting stuck or the butterfly within the throttle body is getting stuck on something..... If neither of those seem to be the issue then possibly a major intake manifold leak?
check and butterfly is moving like it should. No leak.
Does it happen at a certain rpm? At a certain throttle point?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
irrc 3k - 4k rpm
