KillaCam Posted March 6, 2013 Report Posted March 6, 2013 Upload it to a photo hosting site then copy the url. Click the little picture icon in the dialog box on here and paste the url. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
KillaCam Posted March 6, 2013 Report Posted March 6, 2013 If it was me I wouldn't use the cap though. Just bypass it and see if you still blow fuses. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
Wicks Posted March 7, 2013 Report Posted March 7, 2013 Agreed ^ try the same procedure without the cap. Large capacitance's have massive in-rush currents as the caps charge. Either the external cap or the amp's internal power supply capacitance or both could be contributing to a huge inrush current which blows your fuses. Pulling the fuses and adding them later may not fix the issue because you're still abruptly connecting the circuit, just at a different point. If that is indeed the issue, then the best way to avoid it is to get a power resistor and use that inline with your power wire to reduce the inrush current. You only need to use the resistor for a few seconds before the capacitance will be charged up enough that you won't get the inrush anymore. Then just pull the resistor out and connect as normal fairly quickly before the caps have time to dissipate. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
