Capacitor Blowing Amp Fuses Help Please!
1999explorer
alright so my system worked fine until i added a schose 500kfarad capacitor it still worked great after i added it, but last night i decided to rewire my wiring kit to a 4gauage (not the problem) anyway one i got everything ran i went to hook up my capacitor again and it kept making a huge spark then blowing my fuses on my amp and keeps doing it everytime i hook up my power wire off my capacitor into my amp, any help would really help, thanks for the assistance.
Cory
1. remove capacitor
2. throw away capacitor
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
You say your wiring is not the problem, but that is the only thing changed. Logic would assume it is in fact the wiring. Take everything apart, slowly map it out to see what step you messed up on
no but like when i upgraded my wires thats when i did my capacitor and it worked fine till last night when i unhooked everything, is it because the capacitor is still charged?
Like already said if wiring is the only thing that has changed then that has to be it. I want to add... when you're running your power wire don't do it with any in-line fuses in. Leave them out until you have everything ran.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
and i did that i wires everything in and had the inline fuse under the hook out, and when i went to put the inline fuse in it made a nig spark and blew the amp fuses.
What amp fuse are you using?
Pictures of your wiring and connections might help.
B5 Passat Build Log
  • Who's Online   0 Members, 0 Anonymous, 1091 Guests (See full list)
