sbg Posted March 7, 2013 Report Posted March 7, 2013 in need of box! asap! for 2 10' elemental design e5.10.22 i dont have specs and seem to be hard to find. going in ford explorer xlt 96' max dem 37'' from wheel to wheel 18'' H and 33'' from seat to gate, but would like to have some room in back. as of now only 1k of power but down the road going to be runing 2- 2.5 k rms. looking for sub up/ port to back, and most music i go with is rap.. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 7, 2013 Author Report Posted March 7, 2013 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 7, 2013 Author Report Posted March 7, 2013 i suck at design , and want to start 1st thing in the moring... 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted March 7, 2013 Report Posted March 7, 2013 Posting over here: Enclosure Specifications:Fb = 34.5 HzVb = 2.5 ft^3External Height = 15.5 inExternal Width = 33 inExternal Depth = 16 inPort Width = 2 7/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 33 x 16Left & Right Sides = 14 1/2 x 13 1/42x Front = 15 1/16 x 13 1/4Back = 33 x 13 1/4Shared Port Internal Assembly Parts:2 x Front to Back = 13 1/16 x 13 1/42 x Extension = 10 1/16 x 13 1/4 Assembly guide (generic dimensions): Important notes:- The port needs 2 7/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
sbg Posted March 7, 2013 Author Report Posted March 7, 2013 ^^ thanks joe 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted March 7, 2013 Report Posted March 7, 2013 NP Sbg the 45s if you are doing the should be made as follows: The 45s in the back corners should NOT be done in your case.
sbg Posted March 7, 2013 Author Report Posted March 7, 2013 NP Sbg the 45s if you are doing the should be made as follows: The 45s in the back corners should NOT be done in your case. cool thanks i would have put them in lol, going to try and get over to home depot today to pick the mdf up, may even get the stuff cut there because its cold out and snow on the ground 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 7, 2013 Author Report Posted March 7, 2013 Well just got my mdf and got it cut to! + screws and some seal all for 44$. Couldn't get my 45s cut and also need to cut the holes for the subs but can work on that Tuesday ( my day off) http://i1153.photobucket.com/albums/p514/sbg24231/BD944177-F6C1-49D2-A59E-C25281DB7C16-3482-0000042F7A348A71_zpsd785de4a.jpg 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted March 8, 2013 Report Posted March 8, 2013 Titebond II wood glue and MDF/drywall screws are top choices for box building.. wanted to state this before assembly takes place.
sbg Posted March 8, 2013 Author Report Posted March 8, 2013 Titebond II wood glue and MDF/drywall screws are top choices for box building.. wanted to state this before assembly takes place. I got them both I am doing a lil test fit.! http://i1153.photobucket.com/albums/p514/sbg24231/2A052A9C-A2BD-4193-9E8E-DE623A7382FF-3730-00000456BDF956E7_zpsb65eb4a0.jpg 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
