it should fit. but it wont be issue free. alot of these kits have sub par couplers, the clamps are normally kinda cheap and weak. the piping may not be a direct fit and need trimming. the maifolds are normally cheap also. just a heads up
for the most part itll work out just fine. those are just a few thihngs to watch for and expect so your not surprised if a mod or two is needed. just dont go balls out and you will be fine. use it as its supposed to be used.
OP Please do not buy that kit. I can guarantee almost every part that moves will fail on you. That kit is crap. A turbo kit should and does cost around 5 grand. To get all the peripherals to run it on your car will brink you to an 7,000+ total.
You cant go from that price down to 1500 and not spare anything. Right off the bat I can name 20 parts that kit is missing that you will need to buy.
Think about it.
  • 3 weeks later...
+2 on not buying that kit..
#1 Your engine internals are not strong enough to handle the added pressure.
#2 that doesnt look like a real turbonetics turbo, and that kit is crap.
I have a couple of years experience with forced induction, and I agree you cannot just bolt that up.
You need supporting modifications.
Just put a front mount int. ( There is ine inc inthat kit ) on an sti and that was 2200 lol. Just to give you an idea but a decent one will run you 600-1000. . Start with that because your gonna want it first when you start boosting higher psi ( new turbo also )
And agreed with the engine not being strong enough
