VVX Banana Plugs?
So with the VVX's, I noticed the push-pin hole is pretty small, and I have 10 awg speaker wire that I need to run parallel to 4 woofers, which is 3 10-awg wires going to each pin basically... How would using banana plugs work on these? Bad idea? Good? Inputs?
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
With that many drivers I usually use posts and run a separate wire to each driver.
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
By this you mean, like bolts on the side of the box? And using ring terminals on each bolt to change imp.?
Neither do morons
Nothing wrong with banana plugs man! I have build several cables with them.
I guess I was just worried about if there'll be a solid connection at the push pin with a banana plug.
Neither do morons
yes
2004 Dodge Ram
Big 3+ with SHCA
Fuck banana plugs
lol..thanks for the insight bud.
If you use banana plugs, monoprice.com has some that fight 10 ga easily
These do but they tend to move
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2943&seq=1&format=2
These also fit and I like them:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2945&seq=1&format=2
But as Big-A said, I would do bolts. Run each sub pos to a bolt and each sub neg to a bolt, then use the the bolts to wire for impedance. Much easier, just keep track of which bolt is which lol
Nothing wrong with banana clips if you ensure they will stay in and not vibrate out or move around and hit each other, etc.
10501650_10203332501847103_1859383749711
Blown
Yup hate them. Cuz I used them and they did indeed vibrate out Nd arced the terminal
Luckily didn't damage the sub.
Probably not enough power :( lol
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
  • Who's Online   0 Members, 0 Anonymous, 903 Guests (See full list)
