Joshex Posted March 11, 2013 Report Posted March 11, 2013 I would like to get some help on porting this bitch to move a little more air then my prefabbed box. I would like to be tuned around 28-32hz. I would like a port without a bend (if it has too I'll get over it), but I have tried and I keep failing(without bend. The problem I was having was having the port per foot above 12 inches, can I get some help here? I'm also running 12" RF P3 on an AQ1200. Torres: Drawn design: 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here
FosgateLife Posted March 11, 2013 Report Posted March 11, 2013 Make the box a little bigger if you can. Then try different numbers for the port. 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Joshex Posted March 11, 2013 Author Report Posted March 11, 2013 Well, I would like to make it bigger, but I'm already overrating the subs by give or take, .5 cb ft and I'm afraid to go any bigger. I've made boxes before, but "played it safe". 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here
FosgateLife Posted March 11, 2013 Report Posted March 11, 2013 Well, I would like to make it bigger, but I'm already overrating the subs by give or take, .5 cb ft and I'm afraid to go any bigger. I've made boxes before, but "played it safe". Okay then if your over the cubic feet of the sub ehy the hell should it matter the port length??? Make that mother fucker as long and wide as you can to get your desired port tuning???? 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Joshex Posted March 11, 2013 Author Report Posted March 11, 2013 Well, I would like to make it bigger, but I'm already overrating the subs by give or take, .5 cb ft and I'm afraid to go any bigger. I've made boxes before, but "played it safe".Okay then if your over the cubic feet of the sub ehy the hell should it matter the port length??? Make that mother fucker as long and wide as you can to get your desired port tuning????Really? Someone was telling me a rule of thumb is 12 inches port per foot. 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here
TRTC360 Posted March 11, 2013 Report Posted March 11, 2013 generally speaking the closer you stay to 12sqin per cube the flatter your response curve would be, more port tends to lead to a peaky response but it should get louder at and around tuning with more port. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
FosgateLife Posted March 11, 2013 Report Posted March 11, 2013 Im saying that as long as you have the recommended box specs for the woofer after your done with port and sub displacement who cares? Jsut make sure you have at least 12 sq inches of port area and your deisred tuning. Its not hard bro. Hahah just play with the numbers.. You'll get it 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
FosgateLife Posted March 11, 2013 Report Posted March 11, 2013 Im gonna attach a link to something about torres and you can read it.it will help you!! 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Joshex Posted March 11, 2013 Author Report Posted March 11, 2013 Im saying that as long as you have the recommended box specs for the woofer after your done with port and sub displacement who cares? Jsut make sure you have at least 12 sq inches of port area and your deisred tuning. Its not hard bro. Hahah just play with the numbers.. You'll get itGot you know, don't worry about PPF and focus on port area. I think I was just running into some confusion here. Example: If I used all the calculations I have above and in the calculator I do a sqaure 4"x4" port that the length of 6" I get a port area of 16.00 in² and a port area per foot of 3.73 in², tuned at 32.86 Hz 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here
Jskiles Posted March 11, 2013 Report Posted March 11, 2013 I'm a little new to Torres but I came up with this 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
