Burned fused
What fuses are better anl or mini anl. I've melted my fuse up by my battery what would cause that . Did not blow fuse in distribution block in the back or on the amp. Only at the battery blew the fuse and melted everything together power was still going to the amps. What would cause that to happen??
Resistance aka a poor connection causes excess heat. Possibly a short. Like posi wire touch a ground or other metal..
As for fuses. I've always used anl. But a fuse is a fuse. If you need a 100a fuse and they make anl agu and midi style fuses. Choose which one works for your setup or the one you like best. But their all designed to do the exact same thing.
If you need bigger fuses youll find for example you can't get 300a amp midi fuses. Or at least they are more easily found in anl style..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 1 Anonymous, 971 Guests (See full list)
