Sonic Posted March 14, 2013 Report Posted March 14, 2013 Did you just drill 2 holes and pass the wire through on the box ?
will77530 Posted March 14, 2013 Report Posted March 14, 2013 peak seems high for that truck...you may have them wired out of phase or your box could just suck dimensions could help
sbg Posted March 14, 2013 Author Report Posted March 14, 2013 yep but the wires are crazy tight i had to pull them in the box with pliers Did you just drill 2 holes and pass the wire through on the box ? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
CJSmith Posted March 14, 2013 Report Posted March 14, 2013 Your port might be too close to the back hatch and could cause loading issues. also, can you post a pic of your amp settings? *Rebuid in progress*
sbg Posted March 14, 2013 Author Report Posted March 14, 2013 External Height = 15.5 inExternal Width = 33 inExternal Depth = 16 in peak seems high for that truck...you may have them wired out of phase or your box could just suck dimensions could help 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
will77530 Posted March 14, 2013 Report Posted March 14, 2013 External Height = 15.5 in External Width = 33 in External Depth = 16 in peak seems high for that truck...you may have them wired out of phase or your box could just suck dimensions could help port?
sbg Posted March 14, 2013 Author Report Posted March 14, 2013 Port Width = 2 7/8 in External Height = 15.5 inExternal Width = 33 inExternal Depth = 16 in peak seems high for that truck...you may have them wired out of phase or your box could just suck dimensions could help port? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 14, 2013 Author Report Posted March 14, 2013 i have moved the box around and does not help, i can go out a trey to take a pick but its dark lol give me a sec... Your port might be too close to the back hatch and could cause loading issues. also, can you post a pic of your amp settings? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
CJSmith Posted March 14, 2013 Report Posted March 14, 2013 Port Width = 2 7/8 in External Height = 15.5 in External Width = 33 in External Depth = 16 in peak seems high for that truck...you may have them wired out of phase or your box could just suck dimensions could help port? Port seems kind of small IMO. Idk for sure though, box designs are not my forte. *Rebuid in progress*
sbg Posted March 14, 2013 Author Report Posted March 14, 2013 Enclosure Specifications:Fb = 34.5 HzVb = 2.5 ft^3External Height = 15.5 inExternal Width = 33 inExternal Depth = 16 inPort Width = 2 7/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 33 x 16Left & Right Sides = 14 1/2 x 13 1/42x Front = 15 1/16 x 13 1/4Back = 33 x 13 1/4Shared Port Internal Assembly Parts:2 x Front to Back = 13 1/16 x 13 1/42 x Extension = 10 1/16 x 13 1/4 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
