barney91 Posted March 15, 2013 Report Posted March 15, 2013 Hey guys just looking for some help, I'd like to know what ohm load configuratios i can do with six dual 4s Thanks in advance Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
larrys95civic Posted March 15, 2013 Report Posted March 15, 2013 http://www.the12volt.com/caraudio/woofer_configurations.asp Team Superior SPL Former Installer at Driven Sound & Security http://www.drivenss.com All kinds of forsale threads http://www.stevemeadedesigns.com/board/topic/164247-amps-subs-and-misc/#entry2383262 http://www.stevemeadedesigns.com/board/topic/164430-polk-audio-sda6000-sound-bar/#entry2386634 http://www.stevemeadedesigns.com/board/topic/164279-3-michael-kors-watches/#entry2383983 http://www.stevemeadedesigns.com/board/topic/164549-more-items-from-storage/ http://www.stevemeadedesigns.com/board/topic/166967-dd-9518s-amps-kenwood-custom-explorer-dash/ If someone is feeling generous I'd love an original sig LOL
barney91 Posted March 15, 2013 Author Report Posted March 15, 2013 http://www.the12volt.com/caraudio/woofer_configurations.aspThanks I've tried it already but it only does up to 4 subs and doesn't show below 1ohm Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
Noel989 Posted March 15, 2013 Report Posted March 15, 2013 1.33 I think that's the lowest 3 d4 subs is 2.66 ohms So know you have 2 leads 1 from each set (of 3) @ 2.66 if you wire them in parallel you should end up at 1.33 cause that half of it Build Log - http://www.stevemead...-cruiser-el-pt/
barney91 Posted March 15, 2013 Author Report Posted March 15, 2013 1.33 I think that's the lowest 3 d4 subs is 2.66 ohms So know you have 2 leads 1 from each set (of 3) @ 2.66 if you wire them in parallel you should end up at 1.33 cause that half of it that's what i was thinking but if i wire them all in parallel would it be like .7 or something like that Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
larrys95civic Posted March 15, 2013 Report Posted March 15, 2013 sorry try this one http://www.the12volt.com/caraudio/boxcalcs.asp#ser just use each speaker as a coil and enter the impedance per coil Team Superior SPL Former Installer at Driven Sound & Security http://www.drivenss.com All kinds of forsale threads http://www.stevemeadedesigns.com/board/topic/164247-amps-subs-and-misc/#entry2383262 http://www.stevemeadedesigns.com/board/topic/164430-polk-audio-sda6000-sound-bar/#entry2386634 http://www.stevemeadedesigns.com/board/topic/164279-3-michael-kors-watches/#entry2383983 http://www.stevemeadedesigns.com/board/topic/164549-more-items-from-storage/ http://www.stevemeadedesigns.com/board/topic/166967-dd-9518s-amps-kenwood-custom-explorer-dash/ If someone is feeling generous I'd love an original sig LOL
Sonic Posted March 15, 2013 Report Posted March 15, 2013 Each sub wire in series (8 ohms per sub) then wire in parallel with each other = 1.333 Each sub wire in parallel (2 ohm per sub), then wire in parallel with each other = 0.333
sbg Posted March 15, 2013 Report Posted March 15, 2013 ^^ this 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
barney91 Posted March 15, 2013 Author Report Posted March 15, 2013 Alright guys thanks for the help looks like ill be doing .33 haha i kid ill stick to 1.33 Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
Noel989 Posted March 15, 2013 Report Posted March 15, 2013 You can always check the final impedance with a dmm Build Log - http://www.stevemead...-cruiser-el-pt/
