2 SQ HDC312's Box Design
tcullen1
Neither option will benefit from less airspace than you have now but if you had to do it shorter I wouldn't do it for the 12s.
Okay how does this sound, go with the 2 10's for now, run them with brutus for a bit and then upgrade to either another 2100 or look into a single 3-4k. I am just hoping my current electrical with 2 agm's n 200 amp ho could keep up with 3-4k properly. I know I would not be doing the hdc's justice but could they be okay for a couple months on my current wattage. Kinda like a break in period for em lol
200amp HO
Big 3
Diamond Audio S500s (front)
Diamond Audio M65.1a (rear)
Kenwood KIV-BT901
Kicker, Stinger, Knu 0 gauge, 4 gauge
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
SQ HDC312's x 2 36hz
In my view you shouldn't care too much about raw power, going from 2K to 4K will increase your output about 3dB (all other thing being equal) which is barely audible.
Well I think after all this I will just go with the 2 10's. The space in my trunk seems to be a better fit for 10's and more airspace to accommodate 10's properly. Thanks for all your advice. This can get to your brain just trying to get a build together lol
200amp HO
Big 3
Kenwood KIV-BT901
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
Is it possible to get you to make a design for me. I've seen many here you have done and they look very nice. Much thanks again!
200amp HO
Big 3
Kenwood KIV-BT901
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
well the best i got with my dimensions was 3.62 after .32 displacement but no port. I must have downloaded torres wrong because when i put in 3 for walls and recommended length of port @ 20 by 2.5 wide it is not giving me correct cut sheet. The front/back sheet is longer than actual length ugh. The damn thing worked good for last enclosure great. anyone got suggestions
200amp HO
Big 3
Kenwood KIV-BT901
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
scratch the hdc 10's idea there not even f****n available. Totally stressing on an enclosure and cant even purchase em. back to any suggestions anyone has thanks
200amp HO
Big 3
Kenwood KIV-BT901
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
I'm searching all over dif companies trying to pick something close to those. I want to get maximum results with set up. Looking into Fi, and DC. SQ dont have HDC4's in 10's. Anyone I may be missing. Looking to stay around 275 or less per sub. Sorry to keep asking so many things wish my knowledge of this was much more. Its actually stressing me out because my car is just mids n highs lol
200amp HO
Big 3
Kenwood KIV-BT901
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
  • Who's Online   0 Members, 0 Anonymous, 543 Guests (See full list)
