new computer build! pics last page
well i got a bare ssd. Crucial M4 32gb. like a laptop drive it looks like. its like 1" by 2" did i screw up? and non of the sata cables i have connect to it. the GPU has 2 6pin connectors. do i use the ones right off the PSU or the connectors that came with the GPU? it a 6 pin with 4 wires that split into 2 flat 4 pin connectors. 2 of those wires. and i got all these case wires that idk where they go or if i can use them even. if i need something lemme know cuz i didnt get all my fans i gotta put another order in ill just get all the cables and fans i need then. might just return the ssd and put it towards the fans and cables if i need to.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Usethe cable coming from the power supply for the graphics card. Disregard the wire that came with the card.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
The case wires go to the bottom right of your motherboard. Look through your motherboard manual and you should find the pin layout for the case wires.
The pins will be like a 2 pin high, 5 or 6 pin wide configuration.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Dont return the ssd, youll regret it lol. Umm. You most definitely will be able to plug sata cables into the ssd. Take a closer look at the ssd. There are two inputs. One for power from your power supply, and one for data that attaches from your motherboard.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
all of them go there? there is a big blue connector for usb3.0 on front panel but i cant use it on my card idt. but they there are 4 other 2 pin connectors. those go in the bottom right? and a usb connector i think. and if it helps heres the links
http://www.asrock.com/mb/AMD/970%20Extreme3/index.us.asp?cat=Specifications <---- mobo
http://www.xigmatek.com/product.php?productid=173 <---- case
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
im at school now so ill have to do it later tonight but im hoping it works. and the windows i cant burn to a disk. DVD is too small by 100mb... and it wont let me put it onto a flashdrive
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
You have the wrong disk then. You need the 4.7gb DVD-R's
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
I will help you further when i get home
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
thats what my disk are. but it says something like the max ISO cache size for this disk is like 4.2gb then tried a 8gb flash drive but it said it was full when it was empty. thanks for the help so far tho. ill defidently be coming back for more questions.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Ill post pics when i get home so you can see.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
