new computer build! pics last page
i plan on getting that adata one that toms hardware suggested. and 2 more fans. ill post pics later if i can in school. or wait till im home. all put together i could fire it up but id rather get the ssd first
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Did you ever figure out the case wires?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
umm i think so. theres a power switch, led, hdd, reset. i got those hooked up. im thinking the big blue ~12pin connector is the usb3.0 on the front panel. that doesnt work so theres a usb connector that is on the same cord too. thats hooked to a usb pin. im gonna order a new ssd and keep the one i have since i cant return it... :( and 2 more fans. i cant decide if i want to go 1 back 1 side one top. or 1 back 2 top. the case can support 1 back 120mm, 2 top 120/140mm, 2 front 120mm, 2 side 120/140mm
what would u recommend as far as number and placement of fans?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I would recommend liquid cooling over fans. Or even a fully submerged mineral oil rig, those are bad ass. But I'm guessing your not gonna do that. So I would suggest two 120mm fans on the front blowing into the case. And one 140mm fan on the side blowing out.That should give enough airflow. Also, make sure the OS is installed on your SSD and not the normal HDD. Windows will run significantly faster that way.
Did I ever tell you, what the definition of insanity is? Insanity is, doing the exact same fucking thing, over and over again, expecting shit to change. That. Is. Crazy.
Did I ever tell you the definition, of insanity?
He can choose where to install the OS when the installer comes up. As for the liquid cooling... He's fine. I dont see him overclocking much of at all. Stock will do just fine.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Aa for fans, do one side and one back or top. Your graphics card will like the fan blowing air in on it from the side fan. I have four 120mm on the side, one in the bottom, one 200mm in the front, and 3 120mm fans in the top for my radiator. Pumps out ice cold air.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
So not a fan in front? My psu and gpu fans face each other. Which way too? Back out. Side in. top out? Do a front in? Or 2 tops out.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Your psu fan is
Suckong air downward,
Away from your graphics card,
And your graphics card is sucking upward. It's best to have one on the side. Do side sucking in, top/back blowing out.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Well its built for now. Waiting for the ssd to come in so ill update with pics. :)20130406_070031_zps0033adde.jpg20130406_070121_zpsb7296efb.jpg20130406_070129_zps363309cc.jpg20130406_070212_zps0892b039.jpg20130406_070454_zpsd9b68080.jpg20130406_070502_zps1bb121da.jpg20130406_070520_zps73c83a15.jpg20130406_070528_zps3875995e.jpg20130406_070532_zps5d08193f.jpg20130406_070537_zps287ae151.jpg20130406_070540_zps7a274bf2.jpg20130406_070616_zps117aa100.jpg20130404_175741_zpsd96498a7.jpg20130404_175746_zps54f70800.jpg20130404_175758_zps53db137d.jpg20130404_071206_zps4afc0826.jpg20130404_071213_zps020f99ac.jpg20130404_071218_zps63910580.jpg
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
