faralint Posted March 17, 2013 Report Share Posted March 17, 2013 Good day! Can you help me with box. Sub's 15 dc xl. Car - audi a6 sedan (port and sub's to the front) External dimention 40.15(w) * 29.12(d)* 15.74(h). amp aq 3500 0.5 ohm Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3 Link to comment Share on other sites More sharing options...
Joe X Posted March 17, 2013 Report Share Posted March 17, 2013 What vehicle? Link to comment Share on other sites More sharing options...
faralint Posted March 18, 2013 Author Report Share Posted March 18, 2013 What vehicle? Audi a6(c5) 1998 sedan Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3 Link to comment Share on other sites More sharing options...
Joe X Posted March 18, 2013 Report Share Posted March 18, 2013 Really tight, side port: Enclosure Specifications:Fb = 35.3 HzVb = 7 ft^3External Height = 15.75 inExternal Width = 40.125 inExternal Depth = 29.125 inPort Width = 7 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 40 1/8 x 15 3/4Left & Right Sides = 26 7/8 x 14 1/4Top & Bottom = 40 1/8 x 26 7/8L Port Internal Assembly Parts:Front to Back = 17 3/4 x 14 1/4 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 7" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
faralint Posted March 18, 2013 Author Report Share Posted March 18, 2013 Really tight, side port: Enclosure Specifications: Fb = 35.3 Hz Vb = 7 ft^3 External Height = 15.75 in External Width = 40.125 in External Depth = 29.125 in Port Width = 7 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 40 1/8 x 15 3/4 Left & Right Sides = 26 7/8 x 14 1/4 Top & Bottom = 40 1/8 x 26 7/8 L Port Internal Assembly Parts: Front to Back = 17 3/4 x 14 1/4 Assembly guide (generic dimensions): Important notes: - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 7" of free airspace in front of it for proper operation. - Setting your amp subsonic filter to 28Hz is suggested. Thank you! can i place the port in center of the box? And last question Port and sub directed to the front will work well in a sedan? Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3 Link to comment Share on other sites More sharing options...
Joe X Posted March 18, 2013 Report Share Posted March 18, 2013 Yes it can work port/sub front, try to seal off, the box needs to be so big that it would not work well aiming back. The reason I went with port tho the side is that saves space, I can give you a spec for port in the middle if you prefer that, the main problem with port side is when there's car bracing right in front of it, also bear in mind the notes below the pic. Link to comment Share on other sites More sharing options...
Joe X Posted March 18, 2013 Report Share Posted March 18, 2013 Here is a center port version (tighter spec due to the extra panel needed): Enclosure Specifications:Fb = 35.4 HzVb = 7 ft^3External Height = 15.75 inExternal Width = 40.125 inExternal Depth = 29.125 inPort Width = 6 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2x Front = 16 11/16 x 14 1/42x Front Internal = 15 3/16 x 14 1/4Back = 40 1/8 x 14 1/4Left & Right Sides: 27 5/8 x 14 1/4Top & Bottom = 40 1/8 x 29 1/8Shared Port Internal Assembly Parts:2 x Front to Back = 17 1/2 x 14 1/4 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 6 3/4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
throttle98 Posted March 19, 2013 Report Share Posted March 19, 2013 damn. that box is smaller than I thought. I just posted a thread considering 2 12" xl's only b/c of box size. The box I have now is 33" x 16-1/2" x 21" and barely got into the trunk. Now this box is like 8 inches longer and that may be a problem getting it in. I'll check tomorrow. sry to thread jack. good luck. Link to comment Share on other sites More sharing options...
faralint Posted March 19, 2013 Author Report Share Posted March 19, 2013 Here is a center port version (tighter spec due to the extra panel needed): Enclosure Specifications: Fb = 35.4 Hz Vb = 7 ft^3 External Height = 15.75 in External Width = 40.125 in External Depth = 29.125 in Port Width = 6 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 16 11/16 x 14 1/4 2x Front Internal = 15 3/16 x 14 1/4 Back = 40 1/8 x 14 1/4 Left & Right Sides: 27 5/8 x 14 1/4 Top & Bottom = 40 1/8 x 29 1/8 Shared Port Internal Assembly Parts: 2 x Front to Back = 17 1/2 x 14 1/4 Assembly guide (generic dimensions): Important notes: - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 6 3/4" of free airspace in front of it for proper operation. - Setting your amp subsonic filter to 28Hz is suggested. look great, thank you! Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3 Link to comment Share on other sites More sharing options...
throttle98 Posted March 19, 2013 Report Share Posted March 19, 2013 would it be possible to make the box wider to keep the depth down? thanks Link to comment Share on other sites More sharing options...
