Before I build, can you guys check this? (wall experience helpful)
Jessica
My main question is at the bottom of this post: scroll down for that. All the info is as follows:
Alright, This is what i think i want to do. This is pretty much as big as i can build.
This box is for 4 sa-12's on 3200(ish) watts.
B" pillar wall in compact car.
Here are the torres calculations. I just entered the net volume from sketchup because of all the extra baffles and stuff. Easier than typing all that into torres.
Here are pics of the box,
Box volume:
Port Length based on area/width.
Box with dimensions
what you don't see:
I will run some thick all thread front to back for bracing, and to the port wall in a couple spots, but that wont amount to enough volume to make any noticeable difference.
My numbers show 4 runs of 1" all thread only eat up .06 cuft.
Now for the question at hand:
The port area may be too much, but i don't know since it is going to be sealed off to the front of the car and there is not a lot of air space in front of the box.
I would do a center port but i don't have the height to do it and still have a strong enclosure.
Anyway. Any feedback or suggestions are welcome. Hopefully you guys that have experience with walls can chime in.
Thanks.
edit:
i listen to a lot of rock and some country, i play rap just to demo. no chopped and screwed stuff. Music is a must.
I don't get it...where's the question? Are you asking if it is too much port?
yes, that is the question. Plus i just want to see if anyone notices any major issues.
Just want to get some feedback before i go and cut hundreds of dollars in mdf and spend hours and hours just to have a flawed enclosure.
4.5 x 25 is definitely not too much port area.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
