need help please
Hertz_dont_it
i recently (4 days ago) bought a precision power amp from sonic electronix, its the 650.1 which is 650w rms at 1ohm. i have two 10" dual 4ohm rockford fosgate p3s's and i have them wired down to one ohm. i did it exactly as it said on the12volt i checked it three different times to make sure. but there is hardly any sound output from the amp.. i had to crank the gain and bass boost up to hear anything so i turned it back down and its just sitting right now. my last amp was only 600w max at 1ohm and it made those subs bang so i was expecting to hook this amp up and be thrilled but no.. i checked the rca's at the amp and even switched them but nothin.. im not sure whats wrong. if anyone could help it'd be appreciated. thanks
Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1
Sub: Alpine type x 12
dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?
Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system. :shrug:
Verify with a multi meter that you are, in fact, wired to 1 ohm
alright i just did, it's 1.1ohm. another thing i dont know if it means anything but the sub on the right moves more than the sub on the left, it seems like a noticeable difference to me.
What is your subsonic and low-pass set to?
And what does your DC voltage look like at the amp?
Try measuring the output voltage too: set your meter to AC volts and put the probes on the (+) and (-) speaker terminals while playing a test tone at full volume
After we check that, try this:
Pull the subs and measure each coil individually - make sure they all read what they are supposed to.
If that checks out: when you put them back in the box, put them opposite to where they were before - left sub on the right side and vice-versa.
i didnt know what to do with the subsonic but it seemed to have a little more output with it turned up to like 50 which i think is max and the low pass is at 120 roughly. ill go measure that other stuff real quick
What your subsonic does is quiet down lower frequencies. If you turn it up too high, you will quiet down the higher ones too and lose output.
For the sake of testing, turn your subsonic all the way down and your low-pass to ~80hz
yeah i was wrong my subsonic was turned all the way down. i measured it volume all the way up with gain and bass boost all the way down and it sat at about 4.2
4.2 volts on the RCAs or amp output?
What frequency were you playing?
If you gain is all the way down, that's why it sounds quiet
4.2 on the speaker output and i dont know the frequency it was like 44 or 45 or something it was a decaf song and it was the same note the whole time. and it's quiet until i have the gain and bass boost up all the way. even at 3/4 gain and 1/2 bass boost it hard to hear at 35/50 volume which is what i normally have it at.
when i just tested it i had the gain all the way down, same as bass boost, and subsonic. low pass was at 80 and i had the head unit turned all the way up
  • Who's Online   1 Member, 1 Anonymous, 586 Guests (See full list)
