liftedz71withbass Posted March 25, 2013 Report Posted March 25, 2013 Just bought a hydraulic crimper, what does a correct crimp look like? I would like pics please 05 trailblazer Sub-3 Aq hdc3 18 with psi recones (need motors hmu) Sub amps- 2 Lanzar opti 3200 153.1
Skullz Posted March 25, 2013 Report Posted March 25, 2013 A good crimp will act like it is a single piece and last a very long time without ever having to worry about it separating. Set screw lugs IMO are the worst as they have a chance of coming loose over time and under the hood it can be dangerous if they come loose and short out causing a fire. Soldered lugs are capable of coming loose if the connection becomes loose and heats the terminal up to the point of melting the solder and the wire pulls out causing a possible fire, resistance can do some really nasty things if not properly looked after. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
